2001 Chevy Silverado performance responce
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAYA JR
the engine will respond very little when steping on the gas pedle
Feb 16, 2010 at 10:56 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 16, 2010 at 12:15 PM
