2001 Chevy Silverado Oil Leaked Out
70,455 MILES • V8 • 2WD • AUTOMATIC
JCD132
  • 6 POSTS
I made a rookie mistake and forgot to check to make sure the old oil filter gasket was removed with the filter when changing my oil today. Buttoned everything back up with new filter and oil (but unbeknownst to me, with a double gasket) and you guessed it, the oil all leaked out upon starting the engine. It only ran a short period before I realized something wasn't right, but I did hear a pinging noise. I replaced the filter (one gasket this time) and refilled the oil. Started it up and the pinging was there initially, but did go away after a short while of idling. I've driven it a few miles and everything seems fine and no more pinging noise. Did I get lucky or do I need to have it checked out?
Aug 14, 2010 at 2:54 PM
KHLOW2008
  • 41,812 POSTS
Hi jcd132,
If no abnormal noises are present, I would say you were lucky to have noticed the error in time.
Unless any abnormal pinging/knocking noise are present, especially during acceleration, there is nothing you need to worry about.
To check means to remove the oil sump and the journal bearings for inspection, because that is where the wear would be most likely to be affected first.
Aug 14, 2010 at 4:21 PM
JCD132
  • 6 POSTS
Thanks very much. I'll keep my ears tuned for any further noises.
Aug 15, 2010 at 12:02 AM
KHLOW2008
  • 41,812 POSTS
You're welcomed and good luck.
Have an nice day.
Aug 15, 2010 at 1:53 AM
