2001 Chevy Silverado Nothing eletric works
55,000 MILES • V8 • 2WD • AUTOMATIC
CMPCMP
Drove all day no problems then all electric stopped working. no lights, no sound. When it stopped the seat belt warning was flickering. New battery 10 days ago.
Nov 29, 2008 at 5:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check all fuses and relays. Does the anti-theft red light stay on with key in?
Nov 29, 2008 at 5:41 PM
CMPCMP
No red light, with key in.
Nov 30, 2008 at 1:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay. Is it flashing normal with key out? Or not on at all?
How did those fuses and relays check out ?
Nov 30, 2008 at 2:22 AM
CMPCMP
All relays and fuses good.
Seat belt light only flickered til I disconnected battery.
Did not do it again, upon reconnecting.
Problem Solved though.
The cable was corroded under the rubber boot Chevy puts on the positive cable. After cutting off the boot and inspecting soaking/scrubbing with diet Pepsi (Didn't want to waste a regular Pepsi) til it stopped bubbling, rinsed, wiped dry. Reinstalled cables (left off boot), while tightening cables on, lights started to come on, sounds started sounding. Turned ignition to off, pulled key, put key back in, started truck.
I'm not putting boot on because, my father always put grease on the posts and cable ends to keep corrosion from forming.
Check those cables people!!
Thank You
Nov 30, 2008 at 7:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Thanks for this info. It will help us better help others with your same problem. Gotta love that Pepsi. Glad you have it fixed.
Nov 30, 2008 at 8:02 AM
