2001 Chevy Silverado My supercharged silverado
JSAW528
Engine Performance problem
2001 Chevy Silverado V8 Two Wheel Drive Automatic 185k miles
Misses at around 4500rpm and it's not fuel filter or plugs and wires?
Sep 29, 2010 at 9:04 AM
HMAC300
  • 48,601 POSTS
if this is truly supercharged, and you didn't change the injectors it may be leaning out due to the higher boost going into the engine. it should be setting a code if it is doing this unless everything has been changed.
Sep 30, 2010 at 10:44 AM
