2001 Chevy Silverado Motor oil
205,000 MILES • V8 • 2WD • AUTOMATIC
MNO221
  • 49 POSTS
What are your Pros and Cons on switching from 10w30 to 20w50 in my Silverado.
Jun 16, 2010 at 3:10 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
With the miles you have done, there should be no reason not to switch to a slightly heaver oil, it will help with any oil consumption problems that you may be having, you will still get plenty of protection and you will also get a slight improvement in oil pressure.
mark (mhpautos)
Jun 17, 2010 at 1:19 AM
02REDCAMARO
  • 65 POSTS
You might try 10W40 first, it's better in case the weather gets cold all of a sudden, flows better when cold, you didn't say if the engine was leaking the oil or burning it (blue smoke from tailpipe).
Jun 20, 2010 at 9:52 AM
