2001 Chevy Silverado low coolant light keeps coming on and
2001 CHEVROLET SILVERADO
127,000 MILES • V8 • 4WD • AUTOMATIC
ILACARS44
could this be a sensor because my truck is not right now running hot but i keep checking it to make sure it doesn't run hot. also i don't get full heat past control 3 or higher.
Oct 25, 2008 at 10:10 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a7cb0ca86c="ilacars44"]Engine Cooling problem
2001 Chevy Silverado V8 Four Wheel Drive Automatic 127000 miles
could this be a sensor because my truck is not right now running hot but i keep checking it to make sure it doesn't run hot. also i don't get full heat past control 3 or higher.[/quote:a7cb0ca86c]
Have you check your coolant overflow tank? That is were your coolant low sensor is. So, if the tank is low on coolant your coolant low light will come on or flash on and off with the movement of the vehicle.
Oct 25, 2008 at 10:18 AM
