needs a knock sensor replaced
121,500 MILES • V8 • 4WD • AUTOMATIC
MGILROY
I have an 01' 5.3L Silverado that needs a knock sensor replaced. I have the part, just need to know where it is at, how to replace it and how long it should take. Thanks!
Matt
Jan 12, 2009 at 3:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Thanks for the donation. Your knock sensor is located in the valley, under the intake manifold (See Figure Below).
https://images.2carpros.com/forum/automotive_pictures/261618_fig1_4.jpg
Replacement of your knock sensor usually takes between 2.5 - 3.0 hours for an experienced mechanic. To remove, disconnect negative battery cable. Remove intake manifold. Disconnect wiring harness connector from knock sensor. Remove knock sensor. To install, reverse removal procedure. Install sealant to sensor threads prior to installation. Tighten knock sensor to 15 Ft. Lbs. (20 Nm). Hope this helps.. Thanks for using 2carpros.com!
May 5, 2021 at 7:14 AM
GREGOR7875
i have to do this in the same truck and was wondering how it worked out for you
