2001 Chevy Silverado IGNITION
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGWARRIOR
I AM DRIVING OK I STOP AND WHEN I WANT
RE STARTTHE TRUCK IT WOULD NOT START UNTIL
I GO TO THE FRONT AND MOVE THE BATTERIE WIRE EVEN WHEN THE SCREWS ARE VERY TIGHT AND A CLICKNG STARTING IN THE FUSE BOX AND AFTER A FEW TRYS THE IGNITION WORKS OK AND IT WILL HAPPEND AGAIN
I WAIT FOR YOU HELP THANK YOU
Jan 15, 2008 at 2:59 PM
FISHERMAN
  • 937 POSTS
[quote:72d1d471f0="GREGWARRIOR"]Electrical problem
2001 Chevy Silverado 6 cyl Two Wheel Drive Automatic 127000 miles
I WAIT FOR YOU HELP THANK YOU[/quote:72d1d471f0]
Hello !!
That`s a "False Contact" for sure, check the connection at the starter be sure that is tight also remove both battery connectors and clean the battery posts use some sandpaper if possible also check your connectors even if they are "sealed" sometimes they get corrossion inside and "get insulated" (I saw some cases) and replace them if faulty, that should do it!
if the problem persist remove the starter and bench test it could be that the solenoid its faulty and need more "juice" to push the gear and start the motor (starter motor).
good Luck!
Jan 15, 2008 at 3:08 PM
