2001 Chevy Silverado I don't know
160,000 MILES • V8 • 4WD • AUTOMATIC
RODRIDDLE
I have this truck that seems to backfire through the air intake and hesitate to maintain idle rpms. I have switched out the spark plugs, switched out the fuel filter cleaned the mass air device and the throttle control valve but am still having the problem. Now on top of that when I press ther accelerator too fast it seems to loose power. I need to know whats up, THANX
May 11, 2010 at 1:35 PM
2CARPRO JACK
  • 11,533 POSTS
Need to check fuel pressure with a manual gauge to be sure it is in spec.They are sensetive to the correct amount of pressure to make the system work.Is the check engine light on? If so have the PCM scanned to see what trouble codes it may have stored.
May 11, 2010 at 1:45 PM
RODRIDDLE
[quote:432a73550a="2CarPros Jack"]Need to check fuel pressure with a manual gauge to be sure it is in spec.They are sensetive to the correct amount of pressure to make the system work.Is the check engine light on? If so have the PCM scanned to see what trouble codes it may have stored.[/quote:432a73550a]
How do I check the fuel pressure? The check engine light is on
May 11, 2010 at 2:05 PM
2CARPRO JACK
  • 11,533 POSTS
There is a schrader valve (Like a tire) on the fuel rail you will need to use a manual gauge to see what pressure you have.If the light is on, it needs to be scanned, i would probably do this first, as it may lead to the fix without it being af uel pressure issue
May 11, 2010 at 2:17 PM
RODRIDDLE
[quote:fb75881ece="2CarPros Jack"]There is a schrader valve (Like a tire) on the fuel rail you will need to use a manual gauge to see what pressure you have.If the light is on, it needs to be scanned, i would probably do this first, as it may lead to the fix without it being af uel pressure issue[/quote:fb75881ece]
Thanx will go that way
May 11, 2010 at 2:19 PM
2CARPRO JACK
  • 11,533 POSTS
Lemme know what code/codes you get
May 11, 2010 at 2:20 PM
