2001 Chevy Silverado heating and air
JIM MEREDITH
Air Conditioning problem
2001 Chevy Silverado V8 Automatic 176800 miles
when I use the heat in the cool mornings, and then try to switch from heat to air, it dosen't want to make the change, and I continue to get heat, even with the air on and the thermostat turned to the left. I was told by a GM factory mech, it could be an actuator valve, if this is true, could you tell me if he is correct and where it is located
Apr 22, 2010 at 10:10 AM
JIM MEREDITH
I have allready given a donation, what the hell do you want
Apr 22, 2010 at 10:11 AM
AVIEUX
  • 15 POSTS
well my friend there's an acctuator under the dash that has gone bad...i'v had the same issue...on the passanger side there is usually a cover on the air system usually held up by 4-5 screws take that out and there's a small little box thing (acctuator) attatched to the big air box thats the one i had to replace but there's another one on top thats hard to get to that can also go bad
Jun 20, 2010 at 11:50 AM
