2001 Chevy Silverado Headlight Dim
2001 CHEVROLET SILVERADO
50,000 MILES • V8 • 2WD • AUTOMATIC
MWC
Intermittently, when I left off the gas, I notice the headlights dim for about a second then go back to normal. Can't seem to reproduce problem in the driveway to troubleshoot.
Jul 8, 2010 at 10:28 AM
02REDCAMARO
  • 65 POSTS
If your battery is over 4 years old, I'd say replace that first. It's possible that it went bad. If that doesn't do it, I'd say it's your alternator, which also has a voltage regulator inside it. If you replaced a good 4+ year old battery, you would have to replace it soon anyway. It that doesn't fix it, then you've got a real problem, but at least you have eliminated the two most obvious causes.
Jul 9, 2010 at 12:47 PM
