2001 Chevy Silverado fuel pump problems
140,000 MILES • V8 • 4WD • AUTOMATIC
DREWDV
  • 7 POSTS
my truck 3 months ago stalled on me on the freeway had it towed home tried to start it ran for 2 to 5 seconds then cut off. I CHANGE FUEL FILTER AND STILL DID THE SAME THING THEN I LET IT SIT FOR A WEEK AND STARTED TO TAKE TO SHOP AND HAD NO PROBLEMS THEN TODAY IT DID THE SAME THING DIED ON FREEWAY AND STARTS AND RUNS FOR 2 TO 3 SECONDS THEN DIES OUT new filter and lines also
Nov 7, 2010 at 10:49 AM
  • 110,251 POSTS
Have you checked fuel pump pressure? Has the check engine light come on?
Nov 8, 2010 at 12:56 AM
DREWDV
  • 7 POSTS
the pressure is reading 12 psi and not staying it should read between 50 and 60 and no the check engine light has not come on.. we also put a new fuel pressure regulator on to
Nov 8, 2010 at 1:03 AM
  • 110,251 POSTS
It sounds like a bad fuel pump. If you replaced the regulator, filter... the only thing left is the pump unless you have a leak.
Nov 8, 2010 at 1:32 AM
DREWDV
  • 7 POSTS
W have replaced the fuel pump to we are at a loss at what it could be
Nov 8, 2010 at 2:11 AM
  • 110,251 POSTS
Have you checked for sticking injectors, any leaks, are you sure there is 12 volts getting to the fuel pump?
Nov 8, 2010 at 2:16 AM
DREWDV
  • 7 POSTS
yes we checked the injectors we can hear the pump coming on and it reading 12 and no leaks
Nov 8, 2010 at 5:25 AM
  • 110,251 POSTS
If there are no leaks, everthing is working and that is all the pressure you are getting, the new pump must be bad.
Nov 8, 2010 at 5:42 AM
DREWDV
  • 7 POSTS
thank you for your help we will try anew pump i guess and see how it works
Nov 8, 2010 at 6:02 AM
  • 110,251 POSTS
If there are no leaks, the regulator is new, and the fuel filter is new, that is the only thing I can think of. Unless, the power to the pump is lower than 12 volts or the fuel line is pinched at some point.
Let me know what you find.
Nov 8, 2010 at 11:01 PM
DREWDV
  • 7 POSTS
it weird casue we can hear the pump turning on but we are gonna try a new one agian ill check the fuel lines as soon as i can to see if they are pinched
Nov 9, 2010 at 4:01 AM
  • 110,251 POSTS
Nov 9, 2010 at 11:17 PM
