2001 Chevy Silverado enige low idle and stalls
107,000 MILES • V8 • 2WD • AUTOMATIC
TDC242003
what causes my 2001 chevrolet silverado 1500 to start up at a low idle and then dies out. after serval attempt to start engine it will run as normal. second time in 8 months that this has happened.
Dec 2, 2009 at 9:31 AM
  • 110,246 POSTS
Has the check engine light come on? Also, have you checked fuel pressure and fuel pressure drop off?
Finally, has the fuel filter been changed reciently and have you checked for vacuum leaks?
Dec 7, 2009 at 5:28 AM
