2001 Chevy Silverado Engine surges when going up hill or un
130,000 MILES • V8 • 2WD • AUTOMATIC
TC3FAN
Engine surges when going up hill or under load. checked for codes but thiers not any. Now I did get one before for the egr valve,but changed the valve,didnt fix problem, also replace map sensor with no luck. could this be a fuel pump problem or injector problem.
Mar 13, 2009 at 1:42 AM
  • 75,988 POSTS
Check the fuel pressure/Mass Air Flow and Throttle Position sensors-
Mar 13, 2009 at 1:59 AM
