2001 Chevy Silverado engine looses power and surges
167,000 MILES • V8 • 4WD • AUTOMATIC
RUSSELL AND ANGELA
Runs great 99% of the time... It will loose power, surge intermediately and after a few minutes will regain steady power. It has done this after start up as well as after warmed up and running. Also ABS and E Brake indicator lights will stay on occasionally until ignition is turned back off. Could this be a fuel filter or pump problem? Or is it electrical? any suggestions on troubleshooting would be appreciated!
Sep 8, 2009 at 2:36 PM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Sep 8, 2009 at 5:41 PM
QUAGMIRE86
  • 98 POSTS
The loss of power and surging when cold and hot is something I'm dealing with too (haven't figured it out yet). As far as the ABS and E-brake problem you have. Is it just the lights on you dash that light up or is you ABS actually activating? I had a situation where, on dry pavement, when coming to a stop the ABS would activate. It was simply that rust between the wheel bearing and the ABS sensor was pushing the sensor "Out of range" from the toothed wheel. I cleaned the rust off of the wheel cylinder and bolted the sensor back into the hole. Problem solved.
Sep 9, 2009 at 3:58 PM
STRAWMAN1988
[quote:b1f1743862="russell and angela"]Engine Performance problem
2001 Chevy Silverado V8 Four Wheel Drive Automatic 167000 miles
Runs great 99% of the time... It will loose power, surge intermediately and after a few minutes will regain steady power. It has done this after start up as well as after warmed up and running. Also ABS and E Brake indicator lights will stay on occasionally until ignition is turned back off. Could this be a fuel filter or pump problem? Or is it electrical? any suggestions on troubleshooting would be appreciated![/quote:b1f1743862] having same issue e brake light and abs similar mileage did you remedy your issue if so please help at wits end
Oct 12, 2009 at 5:12 PM
STRAWMAN1988
having same issue as you including e brake and abs lights mileage almost exactly the same if anyone has remedied this please help replace everything but fuelpump and ecm at wits end
Oct 12, 2009 at 5:17 PM
QUAGMIRE86
  • 98 POSTS
I found the problem to my loss of power/surging. It was a bad MAF sensor. Now it runs great and the fuel mileage is impoved too. As far as your problem with the ABS/E-brake, not sure what it is.
Oct 13, 2009 at 1:07 AM
