2001 Chevy Silverado Engine Died
167,000 MILES • V8 • 4WD • AUTOMATIC
CLIFFUTLEY
I was driving on the freeway going about 75mph's and the engine just died, power breaks and power steering went out and my rpm's went to 0....what do you think? My power steering pump has been leaking for a while and the tranny sounds weird sometimes, could this be it?
Jan 12, 2010 at 4:09 PM
  • 75,988 POSTS
What is it doing now-See below
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Jan 12, 2010 at 9:33 PM
