2001 Chevy Silverado don't know
90,866 MILES • V8 • 4WD • AUTOMATIC
TIMGENE
it acts like the rotors are warped so I put new ones on but the problems are still there
Aug 31, 2010 at 1:30 PM
MADMIKE1735
  • 951 POSTS
that should have rotors on the rear as well.... if the pedal pulsates after you replaced front rotors, look into the rears.... if its a front end wobble, check the balljoints, tie rod ends, wheel bearings, sway bar endlinks.... if you cant find anything, try rotating your rear tire to the front... may be a tire out of balance...
Aug 31, 2010 at 1:38 PM
