2001 Chevy Silverado dome light and radio
99,999 MILES • V8 • 4WD • AUTOMATIC
RYNO2
my dome light stays on unless i use the dome over ride, also when the doors are shut when i turn off the ignition the radio used to stay on till a door was opened, now it shuts off with the ignition. its acting like it thinks a door is alswase open. i have shut all 4 doors over and over and it still doesnt work.
Sep 19, 2008 at 6:51 AM
DOCFIXIT
  • 18,828 POSTS
Locate each door switch at each door. See if one is damaged most time the rubber bumper comes off and switch stays closed causing your delima.
Sep 19, 2008 at 7:16 AM
