2001 Chevy Silverado Dim electrical
78,000 MILES • V8 • 2WD • AUTOMATIC
JJCHEVY1
All electrical lights in dash,cab, headlights, all went dim. I have checked for loose ground wires, changed the alternator and battery, but no luck solving the problem. Any ideas as to what might be causing the problem?
Feb 10, 2009 at 3:13 AM
  • 110,251 POSTS
Hi:
Have you had the switch itself checked or the body control module (BCM)? If all wiring is good, that is the next direction I would go.
Feb 11, 2009 at 8:15 AM
