2001 Chevy Silverado brake lights and cruise control
2001 CHEVROLET SILVERADO
137,000 MILES • V8 • 2WD • AUTOMATIC
STEVEK220
My brake lights , cruise control and the emergency brake warning light do not work . is there a relay or switch I can check or replace that might fix this problem?
Feb 12, 2009 at 7:42 PM
DON OLIVER
  • 101 POSTS
the brake lights and cruise control are on a switch on the brake pedal under the dash. sounds like the switch is out of adjustment. the ebrake light is also a switch on the linkage but it is a little harder to access but nothing is impossible. good luck
Feb 12, 2009 at 7:55 PM
  • CAR REPAIR CONTRIBUTOR
Check fuses B/U lamps 25amp and the BTSI fuse 10amp in the underhood junction block
Check for power at the brake switch light green and black wire if so close the switch and check for power at the light green and white wire-no power here replace the brake switch-power at the light green and white test the shift lock control solenoid
Feb 12, 2009 at 8:04 PM
