2001 Chevy Silverado back up lights
105,000 MILES • V8 • 4WD • AUTOMATIC
RJREALTOR730
i need to know the color code of the wires for the back up lights and the brake lights coming out of the fuse block under the hood and running under the cab along the frame
Dec 14, 2008 at 7:23 AM
JAMES W.
  • 2,394 POSTS
The colors to the rear are as follows;
Back up-Light green
This circuit also goes through the neutral safety switch.
Tail lights-brown
Brake and turn, right side-dark blue
Brake and turn, left side-light blue. If you have access to a fax #, I can send you the diagram. I can download to here, but they don't come out very clear.
Dec 14, 2008 at 11:16 AM
