serpentine belt tensioner loud winding nose when the truck is on
10,600 MILES • V8 • 4WD • AUTOMATIC
DCTX210
My truck is making a loud winding nose when the truck is on and the noise gets louder when i press on the gas. I was told it was the lower pulley on the a/c belt. I keep getting told to take my truck to the dealer to get it fixed because it is a tricky thing to fix. What is involved on fixing this? I was told that the bearings go out on those pulleys.
May 19, 2010 at 7:16 AM
  • 75,988 POSTS
Drive Belt Replacement - Air Conditioning Removal Procedure
https://images.2carpros.com/forum/automotive_pictures/12900_a1_2.gif
Remove the accessory drive belt. Raise and suitably support the vehicle. Refer to Vehicle Lifting. Remove the engine shield bolts. Remove the engine shield.
https://images.2carpros.com/forum/automotive_pictures/12900_a2_2.gif
Install a ratchet into the Air Conditioning (A/C) belt tensioner adapter opening. Rotate the A/C belt tensioner clockwise in order to relieve tension on the belt. Remove the A/C belt from the pulleys. Slowly release the tension on the A/C belt tensioner. Remove the ratchet from the A/C belt tensioner. Clean and inspect the belt surfaces of all the pulleys. Installation Procedure
https://images.2carpros.com/forum/automotive_pictures/12900_a3_2.gif
Install the A/C belt around the crankshaft balancer. Install a ratchet into the A/C drive belt tensioner adapter opening Rotate the A/C belt tensioner clockwise in order to relieve tension on the tensioner. Install the A/C belt over the idler pulley. Install the A/C belt around the A/C compressor pulley. Slowly release the tension on the A/C belt tensioner. Remove the ratchet from the A/C belt tensioner. Inspect the A/C belt for proper installation and alignment.
https://images.2carpros.com/forum/automotive_pictures/12900_a4_1.gif
Install the engine shield. Notice: Refer to Fastener Notice in Service Precautions. Install the engine shield bolts. Tighten the engine shield bolts to 20 Nm (15 ft. lbs.) . Lower the vehicle. Install the accessory drive belt. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
May 19, 2010 at 7:56 PM
