My husbands check engine light will not go off. He checked the oil and it was fine. What else could be the problem?
Aug 11, 2010 at 1:52 AM
✓Experienced Mechanic
Hi the3re,
The check light is indicating that there is a set fault code in the ECU, you will have to go get a scan done to read the code, this will give you an indication as to the problem.
