2001 Chevy Silverado
JACK THOMPSON
2001 Chevy Silverado 6 cyl
pulling into drivewayput in park it stalls,start back upruns for couple of seconds. It acted like it run out of gas.Has plenty of gas even though the fuelguage doesnt work properly.I checked the fuel filter it had dirt coming out of it,replaced filter and tried to start it still wont start.Also check to see if it was getting spark and it is! Is the Mass Airflow Sensor keeping it fromstarting and if so how do you check to see if its bad? The fuel pump is working,put alittle fuel into throttlebody and starts but dies out! What is the problem?
Dec 8, 2009 at 4:58 PM
CRZYDRVR
  • 432 POSTS
Have you checked the fuel pressure? You may have another air/intake issue as well.
Dec 8, 2009 at 7:27 PM
