2001 Chevy Silverado
81,445 MILES • V8 • 2WD • AUTOMATIC
ROGBA
I have changed the spark plug wiring, new plugs and filters. When driving around 65MPH, the engine stops for a mega-second, the battery light turns on, and immediately the engines starts up again. When I stop I have a hard time starting the engine back on. This doesn't happen all the time, but I am very concern. If you can advise on what the problem might be it will be greatly appreciated. Thank you.
Oct 13, 2010 at 1:27 PM
  • 110,251 POSTS
It sounds electrical. Have you checked the basics such as a weak ground? Check the ground on the engine block to make sure it is clean and tight and the battery terminals are clean and tight.
Oct 14, 2010 at 11:43 AM
