2001 Chevy Silverado
46,000 MILES • 6 CYL • 2WD • AUTOMATIC
KTMARTIN
My husbands check engine light will not go off. He checked the oil and it was fine. What else could be the problem?
Aug 11, 2010 at 1:52 AM
  • 31,937 POSTS
Hi the3re,
The check light is indicating that there is a set fault code in the ECU, you will have to go get a scan done to read the code, this will give you an indication as to the problem.
mark (mhpautos)
Aug 11, 2010 at 1:58 AM
