2001 Chevy Silverado
120,000 MILES • V8 • 4WD • AUTOMATIC
SAC
Engine will turn over but not fire. I have already changed starter and crank sensor. What else do I do.
Oct 25, 2009 at 10:09 PM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 26, 2009 at 12:28 AM
