2001 Chevy Silverado
JAVATIMEDB
the vent direction knob on the dash panel is not working, will not change to vent and is stuck in the defrost mode. how to get to the area to fix the knob and what might be the problem? thanks db
Feb 13, 2009 at 3:32 AM
  • 110,251 POSTS
Hi:
Usually there is a trim piece around the pannel that is cliped once removed, you gain access to the hardware. As far as the problem, the vents are run by vacuum. Before tearing into the switch, check under the dash for broken or disconnected vacuum lines.
Feb 13, 2009 at 8:44 AM
JAVATIMEDB
thanks for the info. db
Feb 16, 2009 at 12:35 AM
