2001 Chev silverado ext cab 2wd, 5.3L, 100k miles
TALBOT
Wind noise coming from rear doors. How to adjust quad doors to remove wind noise? Doors do not appear to align with each other when closed. One door pulled tighter to body than the other
Sep 6, 2007 at 8:34 AM
DENNYP
  • 1,824 POSTS
[quote:0b36876def="Talbot"]Wind noise coming from rear doors. How to adjust quad doors to remove wind noise? Doors do not appear to align with each other when closed. One door pulled tighter to body than the other[/quote:0b36876def]the striker bars are at the top and bottom of the door on the body side.both strikers are adjustable.note: yiu might also have to adjust the front doors if you change adjustment on the rear doors.
Sep 27, 2007 at 4:31 PM
