how do you change a windshield waher pump on a 2000 chevy silverado 1500?
Jan 14, 2008 at 8:09 AM
MERLIN2021
✓Experienced Mechanic
Drain the washer fluid out, unplug the connector, and reove the pump, twist it out, or twist lock ring, which ever you have..
Jan 14, 2008 at 8:19 AM
MRS7441
MEMBER
1 POST
I am in the middle of doing the same job. It looks like you need to removed the battery, and battery plate. Remove the resevoir and the pump is easy to change.
