is it aa wheel bearing assembly or is it separate bearings, a inner and an outer, if its inner and outer bearings you wont need one but you will need a puller and a driver to install the new races to make sure they are square and prevent the bearings from going out.
if it is a wheel bearing hub assembly you will need to use a press to do so.
May 30, 2008 at 9:01 AM
