2000 Chevy Silverado Speed Sensor - Replace
GUENTER77
Transmission problem
2000 Chevy Silverado V8 Four Wheel Drive Automatic
Ref: 6L Pickup
Is there any tranny fluid spill when the tachometer speed sensor is removed?
Can the sensor port be blocked temporarily?
Do any wires plug into the sensor?
Jul 10, 2008 at 12:10 PM
2CARPRO JACK
  • 11,533 POSTS
Yes I believe a small amount of fluid will leak out, but not very much in a 4x4. You would need a plastic plug the same size to block it off effectively . It has a 2 wire connector
Jul 17, 2008 at 2:23 AM
