2000 Chevy Silverado running rough
231,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONTE327
truck wouldnt start, did tune up. Plugs wires cap rotor. still wouldnt start, it was fuel pump, replaced it. 3 days later runs really rough when cold, fine when warm. a month into this thought maybe pump was faulty so I took it back got a new one, no change. replaced throttle position sensor, prior to that removed the wiring harness and it ran fine, plugged in back in ran poorly, so i replaced tps, no change. also when it rains it wont start 80% of the time please help!!!
Oct 30, 2010 at 3:01 AM
  • 110,251 POSTS
Are you getting a good hot blue snapping spark to the plugs?
Nov 1, 2010 at 4:24 AM
GPLOH
I havent checked for that. I know have determined it runs rough only when wet and or rainy outside. 3 in the afternoon it doesnt do it. crack in cap? crank sensor bad?
Nov 17, 2010 at 11:32 AM
BILLMORGAN
I am having the same problem with my 2000 silerado. Runs rough when wet,and if it sits over a 24hr period without starting it,it won't start. New fuel pump,fuel injector,plugs. Any ideas? Wiring shorting out from wetness?
Mar 11, 2011 at 10:59 AM
