2000 Chevy Silverado Question about clutch replacement
2000 CHEVROLET SILVERADO
155,000 MILES • V8 • 2WD • MANUAL
SHANEF82
I have a 2000 silverado 2wd with a manual 5 speed tranny. lately it has been tough to get into 1st when stopped, and i have to over excelerate the engine to keep the truck from dying when backing up. there is also some chattering when the clutch is engaged. does this sound like a clutch issue, or a master/slave cylinder issue?
Jan 24, 2010 at 2:36 AM
  • 110,240 POSTS
If you have a chattering when you pull out, chances are it has to do with either the clutch disc or the pressure plate. As far as the slave, that would make it hard to get into gear.
Jan 25, 2010 at 4:12 AM
