2000 Chevy Silverado pilot bearing
174,000 MILES • 6 CYL • 2WD • MANUAL
ABEJOHNSON
how do i change the pilot bearing once the transmission is taken down
Aug 5, 2008 at 8:22 AM
DOCFIXIT
  • 18,828 POSTS
You can use a puller ie. slidehammer type. have taken them out with a lag bolt just slightly larger than center of bearing screw it in once it hits crank it will back out pilot.
Good luck
Aug 5, 2008 at 8:41 AM
  • 75,988 POSTS
Pack the center of the pilot bearing with grease and use a drift and bang on it-
Aug 5, 2008 at 8:46 AM
DOCFIXIT
  • 18,828 POSTS
In my 45 years I have never seen that work but have seen a lot of guys with grease on their face
Aug 5, 2008 at 8:56 AM
  • 75,988 POSTS
In my 56yrs -Have done it-pullers/slidehammers/chisel they all work too-
Aug 5, 2008 at 9:10 AM
DOCFIXIT
  • 18,828 POSTS
rasmataz
Hey were about same age I'm 58 and spent 3days in Guam in 1972. What you doing there?
Aug 5, 2008 at 9:26 AM
  • 75,988 POSTS
Doc-Read your PM-also you can torched it out but do it fast otherwise you gonna run into problems-
Aug 5, 2008 at 9:36 AM
DDSTAR
Am kinda new here and then again not....have been reading a lot here the past 3 months and giving my bf lots of tips as he has been working on his truck .However, I am still learning how to post a question and in the right place. Rasmataz I would like to request advice from you if possible. Pls message me back
Darlene from dededo
Jan 28, 2009 at 7:54 PM
