How do I change the pilot bearing once the transmission is taken down
Tuesday, August 5th, 2008 AT 3:22 PM
DOCFIXIT
MECHANIC
You can use a puller ie. Slidehammer type. Have taken them out with a lag bolt just slightly larger than center of bearing screw it in once it hits crank it will back out pilot.
Good luck
SPONSORED LINKS
Tuesday, August 5th, 2008 AT 3:41 PM
MECHANIC
Pack the center of the pilot bearing with grease and use a drift and bang on it-
Tuesday, August 5th, 2008 AT 3:46 PM
DOCFIXIT
MECHANIC
In my 45 years I have never seen that work but have seen a lot of guys with grease on their face
Tuesday, August 5th, 2008 AT 3:56 PM
MECHANIC
In my 56yrs -Have done it-pullers/slidehammers/chisel they all work too-
Tuesday, August 5th, 2008 AT 4:10 PM
DOCFIXIT
MECHANIC
Rasmataz
Hey were about same age I'm 58 and spent 3days in Guam in 1972. What you doing there?
SPONSORED LINKS
Tuesday, August 5th, 2008 AT 4:26 PM
MECHANIC
Doc-Read your PM-also you can torched it out but do it fast otherwise you gonna run into problems-
Tuesday, August 5th, 2008 AT 4:36 PM
DDSTAR
MEMBER
Am kinda new here and then again not. Have been reading a lot here the past 3 months and giving my bf lots of tips as he has been working on his truck. However, I am still learning how to post a question and in the right place. Rasmataz I would like to request advice from you if possible. Pls message me back
