2000 Chevy Silverado odometer intermittant
197,000 MILES • V8 • 4WD • AUTOMATIC
SHOTGUNDEXTER
Sometimes the odometer works and sometimes it dosent, not really any pattern to it. When it was colder outside it seemed to not work for about the first 15 minutes in the truck, then work fine- i believe its counting the miles even when not displayed. I am worried because when the odometer display is working the transmission seems to shift fine, but when not displayed it will slip as it shifts into overdrive. Once in overdrive it does not slip. It seems to shift at non-normal times when the odometer is not displayed. All other gauges are working, including the speedometer. The gear indicator goes off when the odometer does, maybe its called "Drive Indicator". thank you.
Jun 14, 2010 at 7:17 AM
SHOTGUNDEXTER
On a different site, ignition switch was suggested--power signal goes from there to the odometer and to the transmission. Any help would be appreciated.
Jun 16, 2010 at 7:25 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have a scan done of PCM including trans if it mis shifts it may set code that will help diagnose
Jun 17, 2010 at 9:08 AM
