2000 Chevy Silverado missing engine
BIKE4X4
Engine Performance problem
2000 Chevy Silverado V8 Four Wheel Drive Automatic
Why does my engine misfire when I'm cruising on the highway. This usually occurs when I'm climbing a gradual hill. If i give it gas the vehicle jumps down a gear pick up and stops missing.
Jan 9, 2010 at 6:49 AM
  • 75,988 POSTS
Check and test the following below:
Oygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Note:If it doesn't apply,disregard.
Jan 9, 2010 at 10:22 AM
