2000 Chevy Silverado Maintenance warning light
209,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOUG JAMES
How do you reset the oil change reminder in the message center???
Oct 3, 2010 at 9:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
turn the ignition ON with engine off. fully press and release the gas pedal slowly 3 times within 5 seconds. if the change oil message flashes then the system has reset properly. if the message stays on then it did not reset so you may need to repeat the procedure again. once it does flash turn ignition off. start engine to ensure light remains off.
Oct 4, 2010 at 10:17 AM
