Clutch pedal goes to floor unless I pump it up about 20 times, then it works for a while. Bad Master or slave?
Dec 14, 2008 at 4:31 PM
✓Experienced Mechanic
Hi there,
It could be either, you will have to check for signs of leaking at both cylinders, replace the faulty one and re bleed, this should fix your problem.
mark (mhpautos)
Dec 14, 2008 at 5:03 PM
