2000 Chevy Silverado Help
189,000 MILES • V8 • 4WD • AUTOMATIC
PJC462
I was driving my truck last night doing about 80mph when all at once the truck down shifted to first gear , speedometer stopped working, abs light came on, parking brake light came on. So I pulled over and shut the truck off and restarted. It was fine for about 1 min then it did it all again. I had to drive it home on first gear (53 miles). Has this happen to anyone. I cleaned all speed sensor with no luck. I noticed now the transfer case is leaking, is this because I got it hot driving home? A mech. told me it might be a bad ignition switch could cause all these eletrical problems , is this possible?
Jan 27, 2009 at 8:33 AM
RHALL77
  • 3,361 POSTS
have it scanned with a code scanner but i have seen a bad neurtal safety switch cause similar problems also.
Jan 27, 2009 at 10:33 AM
