2000 Chevy Silverado Gas tank is crushing
230,000 MILES • V8 • 4WD • AUTOMATIC
STUART HUTCHISON
I have replaced the tank after a leak started near the seam. after about a month the new tank started leaking. I took it to a mechanic and he said the tank was crushed and asumed it had to much vaccum, but wasn't exactley sure what to do to fix the poblem.
Aug 1, 2010 at 3:00 AM
  • 75,988 POSTS
Hi Stuart Hutchison, Welcome to 2carpros and TY for the donation
There's two things that will cause the fuel tank to collasped/deformed/crushed is a wrong gas cap and the vacuum relief valve
Aug 1, 2010 at 10:37 AM
STUART HUTCHISON
Where is the vacuum relief valve located and how does it work
Aug 3, 2010 at 10:09 AM
MERLIN2021
  • 17,250 POSTS
Scan for codes, if the vent valve is stuck a code should be set. Also check the fuses under the hood, there are fuses for EVAP purge and vent solenoids. Testing these requires a GM Tech II scan tool to activate the solenoids to test them..
https://images.2carpros.com/forum/automotive_pictures/62217_Evap_Locations_1.jpg
Aug 6, 2010 at 3:01 PM
