2000 Chevy Silverado fuel pump
2000 CHEVROLET SILVERADO
150,000 MILES • V8 • 2WD • AUTOMATIC
STEVE SHEAR
How can I tell if the fuel pump or the pressure regulator is bad without having to change out both units
Mar 19, 2008 at 12:26 AM
RHALL77
  • 3,361 POSTS
on your intake on the fuel rail is your pressure regulator. disconnect the vacuum hose and check to see if there is any fuel in the line. That is a good indication that the regulator is leaking and needs to be replaces. Fuel pump you can check for fuel pressure. it should be around 60 psi when the key is turned on, and running should be around 53-61 psi. Is there a problem and what is it?
Mar 19, 2008 at 12:32 AM
Check the fuel pressure with a fuel pressure gauge designed for your fuel system. Do the test with and w/o the pressure regulator-
Mar 19, 2008 at 12:33 AM
