2000 Chevy Silverado fuel
110,000 MILES • V8 • 4WD • AUTOMATIC
SPLITSILVER18
i am not getting a fuel pressure at the schrater valve, i have put two new fuel pumps in checked the fuses and replaced the fuel filter, what other problems could it be?
Feb 9, 2008 at 12:20 AM
M8TRIX01
  • 36 POSTS
It could be quite a few differnt things. Do you have acces to the wiring diagram for the fuel pump, and do you have a volt meter or test light.
Feb 9, 2008 at 3:56 AM
SPLITSILVER18
yes i can get a volt meter, i have taken the tank down and will test it tonight, i took the tank down while working in -24 degree weather so i will go inside and thaw out for a while before going back to work on it
Feb 10, 2008 at 11:42 PM
M8TRIX01
  • 36 POSTS
did you get voltage at the pump when you cycle the key on. if so is there a voltage drop on the ground. what did you find?
Feb 17, 2008 at 3:32 AM
