2000 Chevy Silverado Front End Popping Noise
2000 CHEVROLET SILVERADO
130,000 MILES • V8 • 4WD • AUTOMATIC
EASINPC
I have a 2000 Chevy Silverado 1500 that a few months ago was making a popping noise in the front end when I would make a hard turn (like turning into a parking spot). I had the ball joints (on both sides), pitman arm, and something else replaced. Well last week it started doing the same thing again and since it was under warranty for the work they did before I called them and they came and looked at it. The guy I spoke to thought it was the torch bar (I think??). I was wondering if that was what it is, what is that part, what does it do, and could it be anything else?
May 18, 2009 at 9:06 AM
  • 110,244 POSTS
The torsion bar takes the place of a coil spring. Usually there is very little trouble with them. Does it ever make the sound when going straight?
May 18, 2009 at 1:12 PM
SNOBRDRPRO
  • 55 POSTS
It may be the cv axles. What i would do is put it on blocks and run it and turn and have someone listen to where the sound is coming from.
Just thought id throw my 2 sence in.
May 19, 2009 at 5:22 PM
