2000 Chevy Silverado Front End
117,000 MILES • V8 • 4WD • AUTOMATIC
BEPD206
The problem started with a shaky steering wheel but brakes were good. Now when i turn to the left there is a noise like something is grinding or rubbing. the slower i go the slower the noise is the faster i go the faster the noise is. the noise is coming from the passenger side wheel area.
Jan 31, 2009 at 7:44 AM
  • 110,248 POSTS
Hi:
It sounds like a warped rotor is causing the vibration, and worn brake pads are cutting into the rotor. Most likely you need both brakes and rotors.
Feb 2, 2009 at 4:51 AM
