2000 Chevy Silverado Clutch Master Cylinder
178,000 MILES • 6 CYL • 2WD • MANUAL
JLEE714
My clutch master cylinder went out, when I got ready to replace it I discovered that the tabs that the cyclinder mounted to broke off. Is there a replacement part for the "tube" that is mounts to, or do I have to replace the entire firewall,.
Nov 3, 2010 at 2:26 AM
  • 110,248 POSTS
I don't believe there is a replacement part for that. Chances are you will need to fabricate something to make it work.
However, I would recommend contacting a dealer to double check if there is a replacement part. When problems like this come up often enough, they sometimes will manufacturer a part to repair the issue.
Nov 3, 2010 at 3:37 AM
