2000 Chevy Silverado Check Engine
105,000 MILES • V8 • 2WD • AUTOMATIC
JOSECELJR
Idles up and down while not exclerating. Check engine light is usually on but does go out sometimes. Runs worse the colder it is outside. Have changed plugs, whires, fuel pump and filter, and mass airflow sensor.
Dec 24, 2008 at 4:39 AM
  • 110,251 POSTS
Hi:
It sounds like a throttle position sensor (TPS). However, to be sure have the computer scanned for trouble codes at a nationally recognized parts store. Most will do it for free for you and since the check engine light is on, they will find a code which will identify where the problem is coming from.
Let me know if this helps.
Dec 27, 2008 at 3:41 PM
