[quote:00241ac2d4="mikeydoodle"]Other Category problem
2000 Chevy Silverado V8 Four Wheel Drive Automatic 147000 miles
how do you disassemble the drivers door my automatic window is out of its track and wont go up or down[/quote:00241ac2d4]
All you do, is take out the screw covers, undo the screws, and take off the panel. One tricky part you may run into is the door opener handle. Usually those stay connected to the door and the panel should be able to go around it.
Dec 5, 2007 at 2:15 AM
