2000 Chevy Silverado Battery Draining
64,000 MILES • V8 • 4WD • AUTOMATIC
PARKER0712
Hello We own a 2000 chevy silverado we have recently installed a small stereo system in the truck since doing this we have had to replace the battery twice and are going on our third one. just to give you a little aspect on what happens before the voltage drops to 11 and the lights get dim or go out and the gages quit then finally the truck loses power. we have tried disconnecting the system and it still happens!! we have also noticed that when the truck is not turned on and the key is not in the ignition all accessories continue to work as if the truck was turned on. we can not figure out the problem!! we have replaced terminals and batterys and had the altenator tested and it doesnt help any help you can give would be greatly appreciated thank you amber and david parker
Sep 22, 2009 at 3:13 PM
  • 75,988 POSTS
Your question: 2000 Chevy Silverado Battery Draining Do below
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_132.jpg
Sep 22, 2009 at 3:39 PM
QUAGMIRE86
  • 98 POSTS
Double check the wiring of the new stereo. Otherwise, with the accessories working without the key in, kind of sounds like a Body Control Module issue. Have a shop check the module for problems.
Sep 23, 2009 at 6:03 AM
